Displays the contents of the IP routing table for routes with the specified origin.
| auto-peering | Specifies BGP auto-peering routes. |
| bgp | Specifies BGP routes. |
| blackhole | Specifies blackhole routes. |
| bootp | Specifies BOOTP routes. |
| direct | Specifies direct routes. |
| ebgp | Specifies E-BGP routes. |
| embgp | Specifies EMBGP routes. |
| ibgp | Specifies I-BGP routes. |
| icmp | Specifies ICMP routes. |
| imbgp | Specifies IMBGP routes. |
| isis | Specifies IS-IS routes. |
| isis-level-1 | Specifies IS-IS Level 1 routing. |
| isis-level-1-external | Specifies IS-IS Level 1 External routing. |
| isis-level-2 | Specifies IS-IS Level 2 routing. |
| isis-level-2-external | Specifies IS-IS Level 2 External routing. |
| mbgp | Specifies MBGP routes. |
| mpls | Specifies MPLS routes. This option is available only on platforms that support the MPLS feature pack, which is described in the Switch Engine v33.1.1 Licensing Guide document. |
| evpn | Specifies EVPN routes. |
| signaling-protocol [ldp | rsvp-te | static] | Specifies an MPLS signaling protocol. This option is available only on platforms that support the MPLS feature pack, which is described in the Switch Engine v33.1.1 Licensing Guide document. |
| ospf | Specifies OSPF routes. |
| ospf-extern1 | Specifies OSPF External 1 routing. |
| ospf-extern2 | Specifies OSPF External 2 routing. |
| ospf-inter | Specifies OSPFInter routing. |
| ospf-intra | Specifies OSPFIntra routing. |
| rip | Specifies RIP routes. |
| static | Specifies static routes. |
| ospf-inter-vr | Specifies OSPF Inter-VR routes. |
| direct-inter-vr | Specifies Inter-VR leaked direct routes. |
| unicast | Displays unicast routes with the specified origin. |
| vrname | Specifies a VR or VRF. |
N/A.
None.
The following example displays all the BGP routes:
# show iproute origin bgp
The ipv4 keyword was added in ExtremeXOS 11.2.
The embgp, mbgp, and mpls options were added and the ipv4 and multicast options removed in ExtremeXOS 12.2.2.
The evpn option was added in ExtremeXOS 30.7.
The ospf-inter-vr option was added in ExtremeXOS 32.3.
The direct-inter-vr option was added in ExtremeXOS 32.4.
